Seo mod, mod rewrite na webzdarma.cz
Smajda
Příspěvek od Smajda » ned 12. dub 2009 20:59:43
Zdravím, prosím vás, jestli by se mi nékdo nemohl mrknout, proč mi nejde "hezké url"
v htaccess mám toto
    # Lines That should already be in your .htacess
    <Files "config.php">
    Order Allow,Deny
    Deny from All
    </Files>
    <Files "common.php">
    Order Allow,Deny
    Deny from All
    </Files>
    # You may need to un-comment the following line
    # Options +FollowSymlinks
    # REMEBER YOU ONLY NEED TO STARD MOD REWRITE ONCE
    RewriteEngine On
    # REWRITE BASE
    RewriteBase /
    # HERE IS A GOOD PLACE TO ADD THE WWW PREFIXE REDIRECTION
    # PHPBB SEO REWRITE RULES - ADVANCED
    # AUTHOR : dcz www.phpbb-seo.com
    # STARTED : 01/2006
    # FORUMS PAGES
    # FORUM INDEX
    RewriteRule ^/forum\.html$ phpBB3/index.php [QSA,L,NC]
    # FORUM
    RewriteRule ^/[a-z0-9_-]*-f([0-9]+)/?(stranka([0-9]+)/)?$ phpBB3/viewforum.php?f=$1&start=$3 [QSA,L,NC]
    # TOPIC WITH VIRTUAL FOLDER
    RewriteRule ^/[a-z0-9_-]*-f([0-9]+)/[a-z0-9_-]*-t([0-9]+)/?(stranka([0-9]+)/)?$ phpBB3/viewtopic.php?f=$1&t=$2&start=$4 [QSA,L,NC]
    # GLOBAL ANNOUNCES WITH VIRTUAL FOLDER
    RewriteRule ^/oznameni/[a-z0-9_-]*-t([0-9]+)/?(stranka([0-9]+)/)?$ phpBB3/viewtopic.php?t=$1&start=$3 [QSA,L,NC]
    # TOPIC WITHOUT FORUM ID & DELIM
    RewriteRule ^/([a-z0-9_-]*)/?[a-z0-9_-]*-t([0-9]+)/?(stranka([0-9]+)/)?$ phpBB3/viewtopic.php?forum_uri=$1&t=$2&start=$4 [QSA,L,NC]
    # PROFILES THROUGH USERNAME
    RewriteRule ^/clen/([^/]+)/?$ phpBB3/memberlist.php?mode=viewprofile&un=$1 [QSA,L,NC]
    # USER MESSAGES THROUGH USERNAME
    RewriteRule ^/clen/([^/]+)/(topics|posts)/?(stranka([0-9]+)/)?$ phpBB3/search.php?author=$1&sr=$2&start=$4 [QSA,L,NC]
    # GROUPS ADVANCED
    RewriteRule ^/[a-z0-9_-]*-g([0-9]+)/?(stranka([0-9]+)/)?$ phpBB3/memberlist.php?mode=group&g=$1&start=$3 [QSA,L,NC]
    # POST
    RewriteRule ^/prispevek([0-9]+)/$ phpBB3/viewtopic.php?p=$1 [QSA,L,NC]
    # ACTIVE TOPICS
    RewriteRule ^/aktivni-temata/?(stranka([0-9]+)/)?$ phpBB3/search.php?search_id=active_topics&start=$2&sr=topics [QSA,L,NC]
    # UNANSWERED TOPICS
    RewriteRule ^/nezodpovezene/?(stranka([0-9]+)/)?$ phpBB3/search.php?search_id=unanswered&start=$2&sr=topics [QSA,L,NC]
    # NEW POSTS
    RewriteRule ^/nove-prispevky/?(stranka([0-9]+)/)?$ phpBB3/search.php?search_id=newposts&start=$2&sr=topics [QSA,L,NC]
    # THE TEAM
    RewriteRule ^/admin-team/$ phpBB3/memberlist.php?mode=leaders [QSA,L,NC]
    # HERE IS A GOOD PLACE TO ADD OTHER PHPBB RELATED REWRITERULES
    # FORUM WITHOUT ID & DELIM
    # THESE THREE LINES MUST BE LOCATED AT THE END OF YOUR HTACCESS TO WORK PROPERLY
    RewriteCond %{REQUEST_FILENAME} !-f
    RewriteCond %{REQUEST_FILENAME} !-d
    RewriteRule ^/([a-z0-9_-]+)/?(stranka([0-9]+)/)?$ phpBB3/viewforum.php?forum_uri=$1&start=$3 [QSA,L,NC]
    # END PHPBB PAGES
je to vygenerované přímo modem na to...jinak s mod rewrite nemám zkušenosti
jedná se o toto forum
díky všem za rady, pokud budete chtít dalśí info, tak dodám
Nerdy
Re: Seo mod, mod rewrite na webzdarma.cz
Příspěvek od Nerdy » ned 12. dub 2009 21:25:50
Máš zapnuto přepisování? (V ACP)
Pokud ano, napiš co se stane když klikneš na odkaz nějakého fóra a popř. i adresu fóra.
Než se začneš ptát, hledej.
Příspěvek od WhiteWolfSix » ned 12. dub 2009 21:26:35
Najskôr odstráň chybu:
Parse error: syntax error, unexpected ':' in /home/free/tym.cz/f/forum-kytara/root/www/config.php on line 33
Smajda
Příspěvek od Smajda » ned 12. dub 2009 21:30:53
kde to mám nastavit? v tom ACP?
a kde se ti zobrazuje ta chyba? mě se to zobrazuje to fórum normálně, akorát semi nespravuje to url
Nerdy
Příspěvek od Nerdy » ned 12. dub 2009 22:23:23
Na adrese http://www.forum-kytara.tym.cz/ je error... napiš adresu fóra, pokud je to na jiném fóru.
V administraci musíš povolit změnu url...
Smajda
Příspěvek od Smajda » pon 13. dub 2009 10:35:39
pardon.... už jsem zde dlouho (asi tak rok) nebyl, takže podpis nemám aktuální
odkaz na fórum o které se jedná je
http://www.kytaraforum.xf.cz/phpBB3/
a v té administraci se po tom podívám, ale zatím jsem to tam nikde neviděl
Nerdy
Příspěvek od Nerdy » pon 13. dub 2009 11:31:53
Nemáš zapnuté přepisování, protože adresy jsou v základním tvaru viewforum.php?f=
Smajda
Příspěvek od Smajda » pon 13. dub 2009 11:33:16
tak jsem přišel na jednu zajímavou věc. Když natvrdo do adresy zadám /forum.html tak se mi vpohodě zobrazí indexová stránka. když tam zadám např.: novinky-upravy/ (www.kytaraforum.xf.cz/phpBB3/novinky-upravy/) tak to fórum zobrazí, ale jakokdyby bez css nebo prostě je to bez vobrázků a rozházeny. tak uz nevím a to ménění url mám v administraci povolený
Nerdy
Příspěvek od Nerdy » pon 13. dub 2009 11:38:27
Znovu ti říkám, že nemáš přepisování povolené v administraci. To, že se url přepisují, je díky .htaccess souboru, ale aby vše fungovalo jak má, musí to být povolené v ACP.
Najeď do administrace a klikni o dva odkazy víš, nad generováním .htaccess
Smajda
Příspěvek od Smajda » pon 13. dub 2009 11:49:48
jestli myslíš toto tak to povolené mám.... tady je SS
http://kytaraforum.xf.cz/obrazky/lla.JPG
Nerdy
Příspěvek od Nerdy » pon 13. dub 2009 11:58:09
Tak si ještě proklikej ty další možnosti, protože je máš na "ne". Kdyby se i tak nic nedělo, tak si zkontroluj instalaci.
Smajda
Příspěvek od Smajda » pon 13. dub 2009 12:15:25
touš jsem zkoušel, vše na ano, vše na ne, pak to vybírat...prostě uš nevim. Kdyby ste se mi na to někdo koukl tak vám dám práva do administrace. protože už teď sem na tym strávil další hodinu a furt nic ani google mi neporadil
